5 members (Wickedbass, cmayna, pkr, baldeagle, MNSmith), 84 guests, and 5 robots.
Topics128,018
Posts1,055,342
Members48,419
#878490 08/28/2012 5:41 PM
Hi everyone,
New here, just bought a 38 1/2 ton. It's drivable, but needs some things done before I feel comfortable taking it out on the road. My first issue is the lack of brake lights.
There's no light on the truck, so I'll have to rig something up temporarily until I buy a light/bracket for it. The problem is that I don't know where the brake light switch is. The wire is cut at both ends and is just wrapped around the speedometer cable on one end, and sticking out of the back of the bed at the other end. I don't see a place where the switch would mount. I thought I read something here that seemed to say it was on the master cylinder, but I don't see anything there.
Can any of you help point me in the right direction?
Thanks!
1938 Chevy 1/2-ton
More info in the Gallery Forum
She looks good at 50 yards, and 35 miles per hour, on a dark night.
Hoff #878521 08/28/2012 6:52 PM
back yard wrench turner
Check here in the brake section.
http://chevy.oldcarmanualproject.com/shop/1938/index.html
I changed mine to a dual system so I can't help with photos.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
Ex Hall Monitor
Ex Hall Monitor
Your brake light switch is on the master cylinder housing under the floor.
Tiny #878913 08/29/2012 10:31 PM
Hi again,
I'm beginning to think that maybe my truck doesn't have the original master cylinder. I don't see anything resembling a switch on the master cylinder, nor anywhere near the pedal on the toeboard / floorboard that looks like a place to mount a switch. I'll keep looking and researching, since it's not going anywhere soon. Thanks for the suggestions.
1938 Chevy 1/2-ton
Hoff #878916 08/29/2012 10:43 PM
Here is one on Ebay. the switch comes out the end with the brakeline branching off.
http://www.ebay.com/itm/1934-1935-1...tem20ca846b3b&vxp=mtr#ht_1084wt_1113
Wayne
1989 Silverado
Hi Wayne,
Thanks. Boy, that doesn't look like what I have. I'm not sure what I have, so I may have to just rig something up for now. I hope to get the truck up on jack stands soon to get a better look. I'll let you all know what I find, and maybe post a few photos.
1938 Chevy 1/2-ton
Hoff #878975 08/30/2012 9:01 AM
Ex Hall Monitor
Ex Hall Monitor
This is a blow up of the master cylinder. The port for the stop light switch is toward the right end of the housing as you look at the picture, just above the words 'primary cup'.
Tiny #879367 08/31/2012 8:03 PM
Thanks guys. It looks like the master cylinder port for the switch is has a plug in it. I'll order a switch and a brake light and see if I can get it wired up. I'll let you know how I do. Thanks again for the info.
1938 Chevy 1/2-ton
Hoff #879396 08/31/2012 9:44 PM
That thing on Ebay is not a 38 master cylinder.
1951 1 Ton Completed
