2 members (Gray_Ghost, 1 invisible),
179
Mod | | | Forums66 Topics128,109 Posts1,056,269 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 814 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 814 | Has anyone used these? I bought some recently and I can't figure out how the blades attach to the arms. They do kind of click in there, but the connection is so flimsy I can't believe they're supposed to be like that. So I'm wondering if I'm missing something. I seriously doubt they would even stay on the arms with the wipers in operation.
1956 Chevy 3200
| | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | Never changed mine, the PO had new ones on when I got my truck a bit more than a year ago. They're flimsy too, no clips, nothin. They just hook in and sit there. | | | | | Joined: Sep 2011 Posts: 814 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 814 | And you've never had a problem with them flying off or twisting off or anything? I can just picture mine leaving the truck and getting run over by the car behind me.
1956 Chevy 3200
| | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | I have them on my '65 and had to adjustment bend them to stay on after one flew off in a rain storm. I was glad I didn't scratch the windshield. After bending them slightly they fit nice and tight.
My Fleet: 19411953195919651966 1953 Willy's Pickup John Vegetarian- old Indian word for bad hunter
| | | | | Joined: Sep 2011 Posts: 814 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 814 | So did you bend the end of the wiper arm?
1956 Chevy 3200
| | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | I've only needed to use mine once in a light mist so I've never lost one. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The original wipers on the AD trucks are attched in a flimsy way. However, when siting on the window or working, they stay on just fine. Mine have been on for 20,000 miles and have never fallen off. Now if I lift them up well cleaning the window I can easily cause one to come off. | | | | | Joined: Sep 2011 Posts: 814 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 814 | OK, thanks. That's good to know. That's what I noticed about mine too. But I guess the normal wiping motion doesn't dislodge them.
1956 Chevy 3200
| | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | So did you bend the end of the wiper arm? No, I bent the blade "spring" to give it a little more tension. It's been months since I did it and everything has been fine.
