1 members (Brian Moore),
95
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#87832 03/26/2003 1:46 AM | Joined: Mar 2003 Posts: 1 Junior Member | | Junior Member Joined: Mar 2003 Posts: 1 | I am having a problem with the gauges in my 72 Chevy truck. None of the electrical gauges work. The dash lights work but the turn signal indicators don't. The fuel sending unit has been replaced. Any help is appreciated | | |
#87833 03/26/2003 3:36 AM | Joined: Mar 2003 Posts: 13 Member | | Member Joined: Mar 2003 Posts: 13 | My 71 had the same problem after I took the dash out and put it back in. Check your ground wire from the dash to the back of the dash panel. | | |
#87834 03/26/2003 6:00 PM | Joined: Jan 2001 Posts: 198 Member | | Member Joined: Jan 2001 Posts: 198 | One other thing to check is the voltage regulator/stabilizer on the back of the cluster. turn signals should be a different issue unless they both happen to use the same fuse or curcuit breaker. | | |
