1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#87830 03/19/2004 9:13 PM | Joined: Jul 2002 Posts: 102 Shop Shark | | Shop Shark Joined: Jul 2002 Posts: 102 | I bought a 53 project truck that I'm finishing and need to identify the wiring harness so I can do some repairs on it. It has the fuse box and under dash harness and the engine harness. The head and tail light harnesses are with the truck but not installed and in need of replacing. Here's what I know, the column is GM key in and column mounted dimmer and the harness does plug in properly. The number on the fuse box is 5220-A. It has push in fuses not glass type. Is there any other identifying features? I need help on this one. Can anyone steer me in the right direction? Thanks. I do want to keep this harness. The installation so far in very good.
Ron Thompson 51 Chevy 1/2 ton 36 F@rd coupe 65 Riviera
#87831 03/20/2004 4:01 PM | Joined: Feb 2004 Posts: 60 Member | | Member Joined: Feb 2004 Posts: 60 | I assume you have a shop manual?
When wiring my truck I refered to the "factory assembly manual" quite a few times. It was a value for me to complete my wiring. It has all the factory tech drawlings and labels for what goes where.
Good luck, so not more helpful. J | | |
