8 members (2-Ton, Peggy M, TUTS 59, JW51, walter74, moparguy, NJC, 1 invisible),
175
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,055,955 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2012 Posts: 53 | With a lot of help from the guys in the Eng Shop I just finished installing a SB in replace for a 235. Need to know what rear end gear ratio's came in the 58 Apache 3100? I rotated the rear wheel 0ne full turn and got one and three quarter turn on the pinion, which doesn't seem correct. From what I recall that would give me a ratio of about 1.75 which doesn't seem feasable. | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | 3.90:1 is the most common, although there are other ratios and rears available. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes 3.90 was standard, 4.11 came with the OD trans, and there was a 'mileage minder' option of 3.38 .... check in the tech tips for the method for determining the ratio
Bill | | | | | Joined: Aug 2012 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2012 Posts: 53 | Checked the Tech Tips, found nothing on determining the rear gear ratio. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | it's there someplace - need one wheel on the ground if it's not posi - mark the tire, turn the driveshaft 2 full turns
Bill | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Here is a link to checking the rearend ratio in the Tech Tips and it is WRONG big time! Incorrect tech Tip The driveshaft of course makes many more turns than do the wheels. | | | | | Joined: Aug 2012 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2012 Posts: 53 | I just checked it with one wheel on the ground, two complete turns of the wheel gives me 1.75 turns of the drive shart. In my start post I had both wheels off the ground. This still does not add up. Numbers I found on the pinion housing are 707340, does this tell you anything to gear ratio?? it's there someplace - need one wheel on the ground if it's not posi - mark the tire, turn the driveshaft 2 full turns
Bill | | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | There is an axle code stamped (not cast) on the center "chunk" of your axle. It's on the left front side on the flat surface where the bolts are. If you post it, someone here can look up the ratio for you. I have a couple '55 to '59 rears with the code AF, wich is 3.90:1. Most likely what you will have as well. | | | | | Joined: Aug 2012 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2012 Posts: 53 | Do you mean the axle tube?? Don't know what you are refering to as "Chunk".The numbers 707340 are stamped on the front pass side of the housing between the pinion seal and the housing bolts. There is an axle code stamped (not cast) on the center "chunk" of your axle. It's on the left front side on the flat surface where the bolts are. If you post it, someone here can look up the ratio for you. I have a couple '55 to '59 rears with the code AF, wich is 3.90:1. Most likely what you will have as well. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | move the driveshaft 2 complete turns, not the wheel - also make sure you have the slack taken up to start - also be precise, then multiply x2, you seem to have a 3.50, not likely
the 'chunk' is the differential, not the housing, but markings are not always there and might not match what's been changed in the last 50 years ... the definitive way to tell is pull the cover and count the teeth, should be looked at anyway because it's not uncommon to find them with damaged teeth from a pinion loosening up or bearing going out
Bill | | | | | Joined: Aug 2012 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2012 Posts: 53 | I just went and checked the whole rear again. The only numbers stamped on it are 3707340 and under that D1. the numbers run bottom to top (vertical) not rear to front (horizontal).Left out the 3 in previous post. I can post a pic but I can't find a way to post it. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | a casting number won't indicate the ratio .... to use pics here you need to have them hosted someplace like Webshots, and link to them
Bill | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | This pic shows where the id code is stamped on the 3rd member.
Bill Burmeister | | | | | Joined: Aug 2012 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2012 Posts: 53 | There are no numbers stamped where your pic shows. The numbers I mentioned are on the housing that holds the pinion seal close to the housing away from the seal. There are three raised vertical ridges, the last ridge is shorter then the first two. The numbers (370340)are between the first and second ridge and the stamping D1 is between the second and third ridge. I did the rotation again turning the drive shaft and I get a little over two turns on the wheel. If I times it by two I get a gear ratio of about 4.11. So I now think that the rear is either a 390 or a 411. Does that seem correct? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes, standard was 3.90 with the 3 or 4 speed, and 4.11 with the overdrive trans - if it is 4.11 you'd do better with a 700R4 OD
Bill | | | | | Joined: Nov 2004 Posts: 2,404 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,404 | It's more accurate if you do 10 or 20 rotations, then do the math accordingly. My '59 has 3.90 gears.
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Oct 2011 Posts: 206 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 206 | see how many times it takes to spin the wheel ten times.
if it had a manual trans it was 3.9 (taks 39 turns)
If it was a manual with over drive it was 4.11 takes 41 turns
and I think the automatics were 3.23 | | | | | Joined: Aug 2012 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2012 Posts: 53 | Thanks. I will try that. see how many times it takes to spin the wheel ten times.
