2 members (Gray_Ghost, RLB),
194
0
Mod | | | Forums66 Topics128,080 Posts1,056,060 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 57 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2011 Posts: 57 | Hello-
I'm in the process of installing glass boards on a 46 Chev. I noticed by looking at the original boards there are thirteen small holes along the board close to the lip. Were these factory holes or did someone who did work on the truck drill them? The reason I ask is because they are not the same distance apart on both sides. Thank you. Jim- | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | No holes along the front edge or the flat ( step ) area. As I recall, there were a few holes on the top flange where the filler metal between the box and the board fastens down ? For sure, they matched left and right sides. | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | My stock boards had a bunch of holes on the top lip that goes under the cab and the filler panel bolts to. Most of these didn't have anything attached to them. | | |
