2 members (dt235sd, Southerntruck), 145 guests, and 8 robots.
Topics128,077
Posts1,056,033
Members48,433
Hello-
I'm in the process of installing glass boards on a 46 Chev. I noticed by looking at the original boards there are thirteen small holes along the board close to the lip. Were these factory holes or did someone who did work on the truck drill them? The reason I ask is because they are not the same distance apart on both sides. Thank you.
Jim-
No holes along the front edge or the flat ( step ) area. As I recall, there were a few holes on the top flange where the filler metal between the box and the board fastens down ? For sure, they matched left and right sides.
1940 Chevy KC 1/2-Ton
My stock boards had a bunch of holes on the top lip that goes under the cab and the filler panel bolts to. Most of these didn't have anything attached to them.
My 46 GMC on Photobucket
