| | | Forums66 Topics128,164 Posts1,056,977 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#87771 04/06/2004 1:19 AM | Joined: Oct 2003 Posts: 19 Apprentice | | Apprentice Joined: Oct 2003 Posts: 19 | Hey gang, I'm interested in hearing how different people have routed the wiring into the side doors, for such items as pwr windows, etc. I'm familiar with the various jamb contacts out there, but am more interested in an un-interupted type of connection. I've also seen the flexible conduits, but am aprehensive to try them, as the "shearing" angle of the door opening movement on my 50 GMC Panel (hense, my name!!) seems to indicate that they may get kinked. Whats anybody using successfully out there? Thanks!! | | |
#87772 04/08/2004 5:47 AM | Joined: Feb 2000 Posts: 988 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 988 | Paul what part of Michigan are you located in? I am down here in the SW corner. Is this for the front or rear doors? Here is an off the wall suggestion. You might want to look at the chevy venture with a lift gate. The electric is run through the top of the gate but they use as "s" configuration. The 2 hole do not, nor are they meant to, line up. The wires are housed in a flexible courogated rubber sleeve. The entire system twist more then it flexes, if that make any sence?
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | |
#87773 04/08/2004 1:17 PM | Joined: Oct 2003 Posts: 19 Apprentice | | Apprentice Joined: Oct 2003 Posts: 19 | Brian - Thanks for the input! I have looked at those before, but they may not work, as the A.D. doors swing open much wider the the GM van hatches do. Also, when the A.D. doors are closed, there is less than a 3/8" gap between the door shell and pillar, which would crush the wires and this "s" shaped boot. I'm gonna look at the hinges again, you may have given me an idea... which is routing a harness fastened to the hinge arm. Thanks! | | |
#87774 04/08/2004 1:18 PM | Joined: Oct 2003 Posts: 19 Apprentice | | Apprentice Joined: Oct 2003 Posts: 19 | Oh yea, Brian...forgot to answer your question. I'm north of Detroit about an hour, and I want to do this on the side doors. Thanks again - Steve | | |
