1 members (tesa), 142 guests, and 2 robots.
Topics128,080
Posts1,055,953
Members48,430
Folks - I have a 47 1 ton. The PO removed the original vacuum wiper motor in anticipation, presumably, of installing an electric version. I purchased the truck and that was one of the things on "the list". I have purchased a new motor, but have no mounting bracket, or method of knowing how the set up mounts. If anyone has a mount or could take pictures of what the motor set up (vac or electric) under-dash looks like, I'd be much obliged. Rain is coming and I have very little to go on as to how everything fits together. Parts diagrams from LMC are not enough to go on.
Thanks in advance,
Try this link for a view of the original vacuum wiper motor, and how to adjust it.
http://chevy.oldcarmanualproject.com/booklets/4748sctc/index.html
McDriver - Thank you for the info; however I do want to go with an electric wiper - lots of hills around here.... I am looking for the wiper motor mount, but didn't see one in the illustration on how to adjust the vacuum motors.
Again, thanks for the link...
I'll take a picture of mine if I have any time before work tomarrow afternoon.
1953 1 ton panel
I have a few pics you can look at
...click...
there are two styles of motors, one will interfere with the choke cable.
good luck
Moderated by  Dusty53
