7 members (Gdads51, Otto Skorzeny, Wally / Montana, LuckyLee, MickeyP, TUTS 59, kades51),
72
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,051 Posts1,055,710 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 814 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 814 | I just had the vacuum wiper motor on my 56 rebuilt by the Wiperman. It's installed and it works great. But when you turn it on, the first motion it makes is down. In other words, picture the wipers sitting along the bottom of the windshield. You'd think their first motion would be up, but instead, they go down past the lower seal on the windshield. I pulled the wipers off and just watched the pegs while the motor was operating and down is the first motion they make. Is it possible I have the arms on wrong under the dash?
1956 Chevy 3200
| | | | | Joined: Dec 2006 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 97 | Never heard of that ..but i would move the arms and see what happens if not right i would be going back to the wiperman . | | | | | Joined: Apr 2009 Posts: 554 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 554 | I can't recall if it is possible to attach the arms wrong but if you can and did it would certainly be moving the arms as you describe.
Chuck | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I managed to install the arms incorrectly on my electric wiper ...incorrect... ...correct... I don't know if it will relate you your vacuum wiper. You will know right away if they are wrong. The transmission arm will bind. Good luck | | | | | Joined: Sep 2011 Posts: 814 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 814 | That's what I was thinking--that I got the arms on wrong. I'll get under the dash today and see what I can figure out.
1956 Chevy 3200
