0 members (), 52 guests, and 0 robots.
Topics128,050
Posts1,055,643
#87714 05/27/2005 4:40 AM
I
I Offline
No, not that kind.
I have one of those clamp on the column turn signals.
After changing out the flasher it works fine for a while and then the indicator light on the turn signal stays on constantly rather than blinking.
I have a 1940 that I've converted over to 12v.
Any idea what's going on?
#87715 05/27/2005 11:01 AM
My first move would be to check grounds. That seems to cause a great many of the electrical gremlins we have to deal with on these old rigs.
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
#87716 05/27/2005 7:08 PM
you wont believe this but on my 52 half-ton, mine has to been hanging down instead of being tied up in a neat form,, have no idea why, but if it isn't hanging down it acts the same as yours, I too had replaced it with a new one???Fred
Redryder pix
My Hotrod
#87717 05/27/2005 7:17 PM
you can see it hanging down on the 5th pix of my web-site odd/ends of red ryder..Fred
Redryder pix
My Hotrod
#87718 05/28/2005 1:05 AM
Junior Member
Junior Member
I have a question about the flasher on my stock 59. I have a stock 12v system and when I pulled the flasher out it said 6 volts on the casing. Is this normal? I have the same problem as In my 40's and I thought I would change the flasher. Another thing I noticed was that the flasher got hot. Is this also normal
#87719 05/28/2005 3:14 AM
A 12V system should have a 12V flasher. A flasher works by getting hot. When the mechanism heats up it breaks the circuit then it cools to make the circuit again, over and over.
