7 members (68ironhead, 32Fordpuchoptop, 3B, Bill Hanlon, JW51, 53&Me, 1 invisible),
110
Mod | | | Forums66 Topics128,050 Posts1,055,648 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#87714 05/27/2005 4:40 AM | Joined: Nov 2004 Posts: 338 'Bolter | | 'Bolter Joined: Nov 2004 Posts: 338 | No, not that kind.
I have one of those clamp on the column turn signals.
After changing out the flasher it works fine for a while and then the indicator light on the turn signal stays on constantly rather than blinking.
I have a 1940 that I've converted over to 12v.
Any idea what's going on? | | |
#87715 05/27/2005 11:01 AM | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | My first move would be to check grounds. That seems to cause a great many of the electrical gremlins we have to deal with on these old rigs. | | |
#87716 05/27/2005 7:08 PM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | you wont believe this but on my 52 half-ton, mine has to been hanging down instead of being tied up in a neat form,, have no idea why, but if it isn't hanging down it acts the same as yours, I too had replaced it with a new one???Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#87717 05/27/2005 7:17 PM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | you can see it hanging down on the 5th pix of my web-site odd/ends of red ryder..Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#87718 05/28/2005 1:05 AM | Joined: Feb 2005 Posts: 19 Junior Member | | Junior Member Joined: Feb 2005 Posts: 19 | I have a question about the flasher on my stock 59. I have a stock 12v system and when I pulled the flasher out it said 6 volts on the casing. Is this normal? I have the same problem as In my 40's and I thought I would change the flasher. Another thing I noticed was that the flasher got hot. Is this also normal | | |
#87719 05/28/2005 3:14 AM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | A 12V system should have a 12V flasher. A flasher works by getting hot. When the mechanism heats up it breaks the circuit then it cools to make the circuit again, over and over. | | |
