9 members (treegrower, 68ironhead, GRNHydra, Nhluvstruck, 55shaker, MickeyP, elhippie64, David Bush, 1 invisible), 43 guests, and 1 robot.
Topics128,090
Posts1,056,016
Members48,430
#873683 08/10/2012 10:21 AM
Where can I find the spring that goes on the exterior handle. It goes inside the door and keeps the handle level and raises it back up after I open the door. Mine are both broken. Thanks
Jim Carter has them.
My 46 GMC on Photobucket
Called Jim Carter and their anti-droop springs are for 1939 and newer trucks. Anyone else with a source? Thanks
If you can't find a supplier, you may have to find something similar and modify it. I did that on a '38 Plymouth years ago, with good success.
1940 Chevy 1/2 ton pickup "KC"
A day without sunshine is like, well, ..... dark!
