6 members (carbking, Charles in CA, TooMany2count, 1955 1 Series, Donf, FAST55), 344 guests, and 5 robots.
Topics128,160
Posts1,057,054
Members48,463
I just rebuilt a 292, however I was wondering if there are any other engines that ran the same fan?
I didn't want to buy a flex (I like the look of the original mechanical).
Thanks.
Flex fans are out, OK, did you look thru what Summit or Speedway might have.
The only other factory fan I know of is a three bladed clutch fan, found in passenger cars. I have one, but there doen't look to be enough clearance about 1/2 inch in my 63 C20 with a 292. I've been looking for a shorter clutch.
Larry
I don't own a vehicle that isn't old enough to drink.
Larry
Larry,
My 292 is getting put into a 1949 Chevy so I will be moving the radiator support around.
Basically I am looking to see what specs I need to look for. I have a 216 fan that is cleaned up and repainted, but the bolt holes do not line up.
OK, I've run into that problem. I don't have the details, but someone here does. It's the difference between early and late, don't know the years. I've seen fan spacers that are slotted so they will work on both. You need to know the bolt circle of the fan. I'll have to look thru my 292 water pumps and see if I have both diameters.
Larry
I checked a couple of water pumps this morn. The bolt circles are 1 3/4, and 2 1/8. The water pumps I checked were both re-manufactured, one was a 292 early style with large by-pass, the other sbc, and both had the two bolt patterns. That maybe the answer look for a rebuilt with both patterns on it.
Larry
Thanks Larry.
I will have to check my bolt pattern on my water pump this weekend. My water pump is also a re-man. I do have a 216 fan, but a) the pattern doesn't match up and b) even if I was able to fit it to the water pump, the fan diameter looks smaller.
So, you want an OEM fan for a 292? Have you put an ad in the swapmeet? May or may not take a little while to locate one, but you may be surprised.
Steve
'49 3800
'52 3600
'57 3100
Thanks for the responses.
I am thinking maybe it might be an easier deal for me going with an electric fan than the mechanical. I am not looking to move too much around out front.
Still debating in my mind.
Thanks for the idea Ghostride. If I end up going after one, I will post in the swapmeet.
