0 members (),
97
Mod | | | Forums66 Topics128,143 Posts1,056,494 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2009 Posts: 47 | I did a search didnt find anything. Does anyone have a link to bed installation instructions. Like crossmember placement. Im having truck painted and need to temparily bolt the bed without wood. Does this require and special procedures? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | if you don't have an assembly manual [worth getting], look around MarK .... really all you need to do is have the basic box together and bolt some cross members in so it'll sit on the frame - best painted off the truck anyway and with the tailgate off Bill | | | | | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | With the basic box assembled, just use some thin wood strips(strapping) to set the bed height and location. What about the front of the bed panel and back of cab? | | | | | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | With the basic box assembled, just use some thin wood strips(strapping) to set the bed height and location. What about the front of the bed panel and back of cab? | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | We have done several, if you still need some arm-chair coaching/suggestions.
| | | | | Joined: Apr 2009 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2009 Posts: 47 | yes I sure would, I have the bed off now, do I bolt the cross members on with a 1/4" shim? And try to find some holes in bed that line up w/ crossmembers? They are going to paint w/ bed off and reinstall to paint stripe down side. I dont have trim holes in fenders or doors but I do in the bed. I probably need to provide the molding so the lines are straight? thanks | | |
