2 members (Otto Skorzeny, 1 invisible),
136
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,109 Posts1,056,266 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#87696 04/09/2005 1:58 AM | Joined: Mar 2005 Posts: 49 Apprentice | | Apprentice Joined: Mar 2005 Posts: 49 | I just re-wired the entire truck with a Ez-wiring kit. Relays and all. I had the truck running Sunday and went to town with no problem. Today I started it and Every time I would turn the steering wheel I could here the horn relay making noise. The reason I re-wired the tuck was that the old turn signal flasher got so hot they melted. I must have a short in the steering colum. I shut the truck off and now everything is dead. The battery shows 12 volts but I have no power any where else. I have a fuseble link running to the Alternator and it looks okay but not for sure when they do blow what they look like then. There is a 30 amp large silver fuse on the fuse pannel. Is that the main fuse and if so how do you tell if it's blown.
confused | | |
#87697 04/09/2005 7:52 PM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | How are you checking the 12-volts at the battery? I like to use a test light for troubleshooting this kind of problem.
Test between a ground and each side of that big fuse. If you have power on one side, and not the other the fuse is blown. If the fuse is gone you need to determine why, and correct the problem. Otherwise things will get worse not better.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#87698 04/10/2005 2:42 AM | Joined: Mar 2005 Posts: 49 Apprentice | | Apprentice Joined: Mar 2005 Posts: 49 | Found the problem, Bad ground on battery. I had no power at my remote selonoid and I took the ground cabe off and ground down the suface where it's attached. bolted it back on and it works. By the way the silver fuse that I was talking about is a circut braker. Now my question is that It was the horn relay that was making the cracking noise when I turned the steering wheel and the horn is not even hooked up on the steering column. Could the bad ground cause the relay to crackel because now when I start the truck I can move the steering wheel all I want and there is no noise :confused: | | |
#87699 04/12/2005 3:03 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Not sure what's going on with that problem...
