6 members (Donf, mo2cyl, Barney1951, Steelonsteel, Stovebolt48, TUTS 59), 78 guests, and 2 robots.
Topics128,031
Posts1,055,435
Members48,422
#87694 11/23/2003 3:25 AM
I have a '53 half ton that is all original. Could someone tell me what the advantages and disadvantages would be to change to a 12 volt system? I plan to eventually put a larger inline six engine in. Thanks, dyna
#87695 11/23/2003 5:41 AM
With correct size cables and solid ground, a 6v system is just as reliable as 12v. The main advantage is any 12v accessories you might want will be an easy install after the conversion. I kinda like being able to plug the laptop into the cigarette lighter, and I opted for 12v wipers; but there are devices that "step up" from 6 to 12v if you're worried about originality.
I'm running a 6v starter in a 12v conversion and the truck starts fast, since the starter is spinning the engine over faster than it idles. If you go this route, never crank more than a few seconds at a time or you'll be buying a new starter anyway.
You'll also get small benefits such as brighter headlights and the availability of 1157 bulbs. Since 12v systems run half the amps of a 6v, it's less likely a short will cause a meltdown or fire.
1955 First Series GMC 250 1-Ton Panel
Mr. Hedgehog - Follow the build
If you can't laugh at yourself, I'll laugh at you.
