0 members (),
40
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 91 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 91 | Hi I have a 49 chevy P/U and it came in parts. I am working on the steering column. I was wondering about the shifter control that mounts on the steering column just above the steering box. I have the old one but don't know the condition or if it needs to be rebuilt. Have not opened it up but there is a hole in part of the box. which looks like a plug in it. Does anyone have a used one or how to rebuild one. Did not find any on line.
Bennie | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | Its real easy. Just open it up and it should make pretty good sense. Here's the one from my '51 - http://rustyfiftyone.com/2012/04/11/snot/The hole can be plugged with a grease plug/cap available at any hardware store. I got a stainless cap from Ace that was less than a dollar. They look like this - http://www.classicparts.com/images/91-205.jpg - and are identical to the ones from the regular online parts vendors. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | as Eric sez, those boxes are pretty straight forward, mostly you'll just need to clean it out and re-grease it, and probably replace the rubber [available from any repro vendor]
Bill | | | | | Joined: Dec 2007 Posts: 91 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 91 | Thanks so much I think I can handle this didn't know about the hole but you explained it.
Bennie | | | | | Joined: Aug 2012 Posts: 2 New Guy | | New Guy Joined: Aug 2012 Posts: 2 | I shifted my truck to third yesterday and my column shifter broke I have a fifty five first series that has the original column shift. Does anyone know where I can find a replacement shift lever | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the parts wanted section of the swap forums or maybe e-bay
Bill | | | | | Joined: Aug 2012 Posts: 2 New Guy | | New Guy Joined: Aug 2012 Posts: 2 | Thanks I keep looking but haven't found anything out there what a bummer so far but I will keep looking | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | Try calling one of the Vendors like Patrick's or Jim Carter. They may have something laying around. | | | | | Joined: Dec 2011 Posts: 55 'Bolter | | 'Bolter Joined: Dec 2011 Posts: 55 | Pm me and ill send you a guys number that has one for sale | | |
