| | | Forums66 Topics128,154 Posts1,056,840 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2004 Posts: 35 'Bolter | | 'Bolter Joined: Nov 2004 Posts: 35 | Anybody know if 47-53 truck hucaps will fit 49-52 car wheels? They have the clips just like the truck wheels but not sure if it will work. Thanks  | | | | | Joined: Nov 2004 Posts: 35 'Bolter | | 'Bolter Joined: Nov 2004 Posts: 35 | The reason I ask is my truck has 5 lug rear and disc brake conversion, and I'm hoping that I can use the car wheels with my original hubcaps to keep a stock look to the truck. | | | | | Joined: Aug 2011 Posts: 835 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 835 | Why not try it and see?
Kurt | | | | | Joined: Nov 2004 Posts: 35 'Bolter | | 'Bolter Joined: Nov 2004 Posts: 35 | don't have the wheels, and thought I would find out if it would work before wasting time finding and buying some only to find out they wont fit.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | well I know the early 50's car caps work on TF wheels, the early car wheels and the truck wheels have 6 clips, the later have 3 clips, same circle .... I suspect any from the same size wheels [15 or 16"] would fit
Bill | | |
