0 members (), 87 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#876512 08/21/2012 6:44 PM
hi I am new to the forum, posted my intro in the welcome section. I have a few questions maybe someone can help with. I am going to pick up a 52 1 ton pickup very soon, it has the stock 216 and grunt 4 speed and rear end.
1. how fast and what kind of milage will it get left stock?
2. I have a 4.11 1 ton rear from a late model chevy van. Was told it is p track, if I install it with the stock motor and tranny what kind of speeds and milage?
3. If the two above questions are not a good possibility for normal driving, is it possible to install a turbo to the 216 and increase the H.P. and what would that do for speed with the stock tranny, engine and the 4.11 rear end??
I would like to make this truck a daily driver. I drive mostly through the county and state roads where the speed limit is 55 or 60 mph. I would like to have the ability to do a little more if necessary with out blowing the engine thru the hood.
thanks for your time!!!
Scott
pushrodscott #876592 08/21/2012 10:47 PM
Welcome! I'd say 45 is about as fast as you'ld get at about 2400rpm. If your target is 55-60 then the 4.11 gear set should put you in a comfortable powerband. Again 2400 would put you at about 60mph. Not sure if you have a pickup but if you have a dual tired axle, your donor single may work. From what I've seen on here most people tend to get about 10-12 mpg. Some claim better near 18 in their 1/2 tons. Many upgrade their engine to a full pressure 235 or 261. Check the tech tips forum.
1941 G506
More
1946 3800
Pic
More
1946 3600
Pic
More
1924 Ford Model T Fordor
641Workmaster #876656 08/22/2012 8:52 AM
I drove a stock (other than later 235) 52 1 ton for several years, it took me everywhere I needed to go, 5.14 gears and all.
I then swapped to a later rear with 4.56 gears and it was better, fine around town but a tad slow on the highway, 50-55 was quite comfortable even for an 8,000 mile round the country trip.
My next plans for the truck include a Detroit Diesel 3-53T at 140 HP, a 5 speed Spicer with 0.84 OD, and a 14 bolt from a P-30 with 3.73 gears. That seems like the perfect combo for me.
If you stick with the 216 or upgrade to a 261 the 4.11 gears should be great, might swing 3.73 with the 261.
Not worth adding a turbo to an old gas engine (in my opinion) much less an old 216. The 261 is the easy and economical upgrade.
Gear and speed calculator
http://www.onlineconversion.com/bigger_tires.htm
My 235 liked about 2,400-2,500 RPM on the highway for hours and days at a time and could do more if necessary.
Enjoy!
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
Grigg #877293 08/24/2012 3:50 PM
thanks for the info, I have a 1954 235 motor stashed away, waht will it do for me at the same 2400 rpm. Hor hard on the 216 is 2400 rpm???
Scott
Moderated by  Dusty53
