| | | Forums66 Topics128,164 Posts1,056,983 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | I'm trouble shooting the typical 235 rochester B stumble...
I'm trying all the solutions I've been reading, float level, mixture, and more...
I haven't given up yet, but I want to know about vacuum advance. When I give a shot of gas, I observe the distributor twist quickly, and back.
If I hold the pedal down, should the distributor stay advanced until I let off the gas, or is it a pulse like I'm observing?
Mark | | | | | Joined: Feb 2004 Posts: 29,865 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,865 | The advance should pull opposite distributor rotation and stay there with a steady throttle. When you let off the gas, it will return to the retard position for idle. If it's moving CCW quickly and returning even with the RPM up, you've got a leaky vacuum advance diaphragm. Replace it. Jerry
| | | | | Joined: Feb 2008 Posts: 212 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 212 | I just installed a new vacuum advance unit on my distributor in the 58 apache. I was wondering about the same thing. Mine did nothing before I changed it, so now the distributor does a very sudden twist whenever I hit the gas.The tone of the engine is different also. | | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | The advance should pull opposite distributor rotation and stay there with a steady throttle. When you let off the gas, it will return to the retard position for idle. If it's moving CCW quickly and returning even with the RPM up, you've got a leaky vacuum advance diaphragm. Replace it. Jerry Ya, it's returning right away. I'll swap it out, thanks Jerry. | | |
