3 members (Rich'sToys, 54farmtruck, 1 invisible), 96 guests, and 1 robot.
Topics128,157
Posts1,056,875
Members48,456
In an effort to achieve a more "stock" look, I came across a nice used oil bath unit that's in very good condition (still has original sticker on cover). My engine is a 56 235 that was transplanted into my 49 1/2 ton. It's got a single bbl Rochester carb with a 2.5" opening.
Here's the problem, the oil bath unit I just got appears to have a 2.25" opening to fit a smaller diameter carb than mine. It has the original long clamp and handle and I'd like to find a way to use it. Is there such a thing as an "adaptor" to attache a 2.25" diameter airfilter housing to a 2.5" carb? Would an exhaust adaptor do the trick?
May convert it to a paper element at some point, but for now would like to securely mount it on the carb and use it as is.
Open to suggestions.
Mike
Riding in the Passing Lane
Good idea. I have made spacers/reducers out of ex. pipe adapters.
1972 Chevy c10 Cheyenne Super
