| | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 461 | Here we go. 1956 235 timing at tdc is 0, starts and runs at about 1000 to 1200 rpm idle with 1/4 choke. Push choke all the way in or no choke and it shuts off. No backfire, miss or other distrib. problems, plugs are new and gapped correct as are the points. Has a carter yf that had a kit put in about 6 months ago. When shut off, carb smokes as if it still is getting a little fuel.
I'm thinking it needs a new float in the carb and that the float is not sealing off. Maybe back timing off 4 degrees tops. The engine has a little bit of a hotter than stock cam, but that idle is still way to high. Stock idle was around 475 I believe?? Any ideas? Thanks for your time.
Hank
Last edited by Hankdogg; 08/19/2012 7:43 PM. Reason: big fingers...little keyboard
| | | | | Joined: Aug 2004 Posts: 1,417 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,417 | If It dies when taken off of choke, the first suspect is usually a vacuum leak somewhere.
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Feb 2011 Posts: 1,362 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,362 | And have you tried opening the idle mixture adjust screw? If it needs choke its not because of float needle not shuting off. How does it go under power?
Kicking self for selling off my Taskforce trucks. Still looking for an LCF or conventional big bolt in decent shape.
| | | | | Joined: Sep 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 461 | Power is really good, runs strong, just idles way too high and needs 1/4 choke. Checked for vac. leak.....nothing there. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | When you shut it off, look down the throat & blow the smoke away. See if there is any gas running into the carb. If so you have a float or needle & seat problem. Its also posible the diaphram is ruptured or not installed correctly. They are prety flimsy. Make sure it comes off fast idle when the choke is off. Have you tried slowing it down with the idle speed screw? It could be the idle mixture screw is too lean. You usually want a little more spark adfvance from the zero mark. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Sep 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 461 | Thanks Wrenchbuilder. I agree that the carb is probably my big issue. Thanks for the tips, i'll check them and be sure. Do you think the old throttle plate could be causing a vacuum leak? Just an idea i had.
Hank | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Check the condition of your plugs If you have been running 1/4 choke for a while they may be fouled. My 235 will still run as low as 300rpm without shutting off.(before setting idle) ...click... Try a new kit in your carter, re time, adjust mixture screw Good Luck | | |
