5 members (Gdads51, TUTS 59, 55shaker, MikeStone1953, Wally / Montana), 138 guests, and 1 robot.
Topics128,109
Posts1,056,258
Members48,437
#875026 08/15/2012 6:43 PM
jwc
Offline
have a 54 3100 w/ 235. got new plugs & new wires. when all connected, engine runs rough. if i pull spark plug wire off #1 plug and let spark arc to plug, engine runs smooth. took a timing light to all wires, and the strobe works. if i attach timing light to #1 when connected to plug, no strobe. if i disconnect #1 wire and let arc, the strobe works fine. am gonna try new distributor cap and rotor next. any other hints or ideas? thank jwc
Ex Hall Monitor
Ex Hall Monitor
That's just weird. Swap the #1 & #6 plug wires and see if the problem moves to #6. If so it's likely the wire. Factory defects do occur.
You've got a spark plug that's shorted to ground. Swap the plug and the problem will go away. Even brand new plugs can be bad- - - -I've seen several of them.
jwc
Offline
jerry
thanks. it seems to have done the trick.
r/
joe
