1 members (baldeagle),
158
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 32 'Bolter | | 'Bolter Joined: Oct 2011 Posts: 32 | have a 54 3100 w/ 235. got new plugs & new wires. when all connected, engine runs rough. if i pull spark plug wire off #1 plug and let spark arc to plug, engine runs smooth. took a timing light to all wires, and the strobe works. if i attach timing light to #1 when connected to plug, no strobe. if i disconnect #1 wire and let arc, the strobe works fine. am gonna try new distributor cap and rotor next. any other hints or ideas? thank jwc | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | That's just weird. Swap the #1 & #6 plug wires and see if the problem moves to #6. If so it's likely the wire. Factory defects do occur.
| | | | | Joined: Feb 2004 Posts: 29,803 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,803 | You've got a spark plug that's shorted to ground. Swap the plug and the problem will go away. Even brand new plugs can be bad- - - -I've seen several of them. Jerry
| | | | | Joined: Oct 2011 Posts: 32 'Bolter | | 'Bolter Joined: Oct 2011 Posts: 32 | jerry
thanks. it seems to have done the trick.
r/ joe | | |
