2 members (Wally / Montana, TooMany2count), 32 guests, and 5 robots.
Topics128,014
Posts1,055,324
Members48,419
#875876 08/19/2012 12:56 AM
There is a grease fitting on the aft end of my transmission where the driveline conects. I can't find it in the few manuals I have and would like to know what kind of grease to use in this area and how much?
transmission
http://good-times.webshots.com/photo/2872350510102578061mqIdDQ
This fitting has been observed by many people and there has been much speculation on what is was used for.
I think it was used to put transmission fluid into to the u-joint compartment/bell. This is pure speculation. It would be nice to see GM documentation.
I would agree with Tim - I don't think it would be used for "grease". That section is open to the transmission gear assembly, and requires gear oil. There are certain types of lube guns designed for gear oil. In my early days working at the local Esso, we had a pressurized gun for gear oil that would also fit a zerk.
tcox #875906 08/19/2012 9:47 AM
ODSS Lawman
ODSS Lawman
Tim is correct. It is the opening to lubricate your u-joint. By far it's the most missed service item on our trucks. From the factory, it had a square headed pipe plug. At some point someone put this fitting on you truck.
The service manual does say your u-joint needs one pint of gear oil. I would not recommend grease. I have seen u-joint failure partially caused by grease (possibly not enough).
I use a cheap small hand pump with a small hose to get gear oil to that spot one a year. I drive between 3000-4000 miles annually.
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
SWEET #875908 08/19/2012 9:58 AM
Makes sense. Thanks to all
