| | | Forums66 Topics128,062 Posts1,055,854 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2012 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2012 Posts: 37 | I see that there is a modified bellhousing for a 216 available that uses a newer trans. my 46 3 speed is tired and considering my options. looking for opinions or if any one out here has gone down that road? | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | I am not familiar with the modified bellhousing you speak of. Do you have a web link for it?
Drew
| | | | | Joined: Apr 2012 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2012 Posts: 37 | Jim Carter's catalog, jimcartertruckparts.com special modified bellhousing to replace non-synchronized trans 1931-47..Part # REME570 says you can use a 1948-64 4 speed open drive. anyone with any info on this set up let me know. does shifter stay in same area on floor, is this an easy swap, and can I change just my 46 rear end pumpkin to get the open drive and keep the 1946 axles & rear end housing. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I am sure Carter must re-drill 1938-46 bellhousings for the later transmissions. There is no 1948 or later trans that will have the shifter in the same position. If you are going to that bellhousing a S10 T5 trams would be the way to go. 1940-54 axle housings will except the 1955-62 1/2 ton center section making it a easy open driveline conversion. The axles are all the same spline also. You will need to remount the axle housing solid to the springs.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | I am sure Carter must re-drill 1938-46 bellhousings for the later transmissions. I believe The modified carter bellhousing is a 48-54 bellhousing that has been welded to accept the prewar brake and clutch pedals. Rods 46, I'm sure you are aware that changing the transmission will likely force you to go with a new rear axle. There are many transmissions that can work with the 46 bellhousing with an adapter plate. Do you have a specefic transmission in mind? As stated above, the t5 is a popular swap. There is a tech article on this site detailing installation in a deco or prewar pickup. Below is a link to the tech article. http://www.stovebolt.com/techtips/tranny/sandoval/index.html | | | | | Joined: Apr 2012 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2012 Posts: 37 | not sure on my direction, but the pumpkin swap sounds good. does the s10 trans shifter locate in the same area as the stock 3 speed I have? and do I need to modify the e-brake bracket? my battery is already under the hood. my truck is pretty stock and I feel bad when I think of modifying things but I do need driving to be a pleasure, not a chore. | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | The shifter tower will likely move back about 8 inches. If you have the park brake lever that comes up through the floor on the right of the transmission, you will need to make an adapter for your parking brake. It might be easy to scab some parts from another truck like the 47-54 trucks and run a foot pedal on the driver side, or a pistol grip brake like the 1955-1959 trucks had bolted under the dash. | | | | | Joined: Apr 2012 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2012 Posts: 37 | my truck has the hand brake lever to the left of the shifter, bolted onto the brake master cylinder, not on the trans. Moving the shifter back sounds very close to the seat? | | | | | Joined: Feb 2003 Posts: 1,377 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,377 | I used the modified bellhousing to install the T-5 in my 37,the shifter will sit back from the original location and I made a bracket to attach the park brake to the 5 speed. The parking brake handle will sit over about 2 to 3 inches from the original location and required doing some modifications to the battery box and a thinner battery. | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | I chose the machined adapter. It moved my shifter back about 8 to 8-1/2 inches, it moved my emergency brake over about 2 inches, but I set it up a little further back in it's resting position to keep it closer to the shifter. By using the adapter, I could use my brake and clutch pedals mounted in their stock position. The transmission sits right next to my master cylinder which I changed out to a Corvette dual master cylinder. I altered the cross member and the tail of the transmission sits right on top of it at dead center, front to back, plus or minus 1/2 inch. It looks great on top and great on the bottom. You can see a shot of the shifter on my truck web site below. It all took some work and time, but it is well worth it! No modifications to the battery box. It clears by about three inches.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
