0 members (),
136
Mod | | | Forums66 Topics128,193 Posts1,057,259 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#87561 04/21/2004 5:09 AM | Joined: Oct 2003 Posts: 38 Member | | Member Joined: Oct 2003 Posts: 38 | I have a '66 short step and I am customizing it quite a bit. I took the gas tank out of the cab and bought one of the PE tank kits from Jim Carter. I got it all installed and with the tank full, half or almost empty it will sometimes read full, sometimes almost empty at the gauge. I am wondering if I have a grounding problem, however I am also wondering about the ohms. I think that the '66 should have a 90 ohm sender and that is what is in it.. Any ideas?
Be Happy and Live a Good life filled with Love and Happiness.
#87562 04/21/2004 1:56 PM | Joined: Feb 2001 Posts: 96 Shop Shark | | Shop Shark Joined: Feb 2001 Posts: 96 | Hope this helps http://auto.howstuffworks.com/fuel-gauge.htm then under more links there is a troubleshooting link http://auto.howstuffworks.com/framed.htm?parent=fuel-gauge.htm&url=http://members.core.com/~faldrich/fuelgage.htm | | |
#87563 04/27/2004 10:10 PM | Joined: Apr 2004 Posts: 21 New Guy | | New Guy Joined: Apr 2004 Posts: 21 | I put one of those '72 blazer tank kits in my '63 c-20. It was a perfect bolt in. The sending unit was another story. I had two new sending untis, one for the new tank, and one for the old tank. Take the actual rheostat piece off the one for the old tank and put it on the new one. That's the piece in the middle that the float arm attaches to. It looks like a curved spring. This will give you the correct ohms for the guage. My swap went without a hitch.
Glen E.
