| | | Forums66 Topics128,050 Posts1,055,676 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 142 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 142 | Are the rear fenders on a (56)3200 the same length as a 3100? Thanks
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | It looks like they are the same , unless the 3100 left fender has the indentation for the spare tire carrier (the 3200 left fender would not have the indentation). Someone will correct me, if I am wrong. | | | | | Joined: Jun 2012 Posts: 142 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 142 | My 3200 has an indentation on the right side low. The tire sits on the running board and bolts to a holder. The indent was done clean. | | | | | Joined: Dec 2006 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 97 | I am sure they are the same never heard other wise . | | | | | Joined: Dec 2011 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 35 | The boys are correct that they are the same,except the driver side with a spare tire cutout mount the same , same length, howevr the indent is different on a 3100 than a 3200. Indendt on the 3200 is shorter and deeper than the 3100. Tire mounts are also different.Tried both on my 3200 and found this out.
'57 3200
