6 members (walter74, Hotrod Lincoln, mason86, 55shaker, Otto Skorzeny, dt235sd), 72 guests, and 1 robot.
Topics128,050
Posts1,055,684
#875547 08/17/2012 4:56 PM
Are the rear fenders on a (56)3200 the same length as a 3100? Thanks
Midpiner #875553 08/17/2012 5:22 PM
It looks like they are the same , unless the 3100 left fender has the indentation for the spare tire carrier (the 3200 left fender would not have the indentation).
Someone will correct me, if I am wrong.
tclederman #875568 08/17/2012 6:00 PM
My 3200 has an indentation on the right side low. The tire sits on the running board and bolts to a holder. The indent was done clean.
Midpiner #875807 08/18/2012 6:25 PM
I am sure they are the same never heard other wise .
Never take a sleeping pill and a laxative at the time.[/i]
1955 Chevy 3100
More pix on Photobucket
V
V Offline
The boys are correct that they are the same,except the driver side with a spare tire cutout mount the same , same length, howevr the indent is different on a 3100 than a 3200. Indendt on the 3200 is shorter and deeper than the 3100. Tire mounts are also different.Tried both on my 3200 and found this out.
'57 3200
