9 members (Hotrod Lincoln, sron48, FAST55, Uncles51, gswbbc, Hanks custodian, 32Fordpuchoptop, Joe W, 1 invisible),
158
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,041 Posts1,055,479 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | I hope this is the right place to post. My running boards are finished and ready to install.I need to know the correct size of the bolts that attach them to the truck. They look like a standard carriage bolt. Thanks Steve | | | | | Joined: Jan 2011 Posts: 152 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 152 | They are a 1/4" carriage bolt with a larger than standard head.
49 chevy 1-ton. It is a work in progress but it's getting close. 49 1 Ton Pics | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 |
| | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | If you have trouble finding the correct bolts, try Fastenal.I bought a running board bolt kit for my '54 3100 from The Filling Station. Also available from other suppliers. Filling Station #GM-1152 The Truck Shop #47-06605 I haven't used them yet, so I don't know if they are correct. I'll find out next week when I remove my running boards to strip and paint. Doesn't look like the bolts on my running boards are elevator bolts. Suggest you also buy running board to cab seals, running board to cab seals mtl retainer, and running board to fender gaskets. Available from most suppliers.
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | Lonnie, thanks for the good info, but what is a mtl retainer? Steve | | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | Thanks EdPruss, The old ones look like 'elevator bolts' with the thin profile. The typical 1/4" carriage bolt has a smaller head but looks like it would work. It isn't one of those specialty items that always cost more. Back in the day, that is probably what a farmer would have used. Just my opinion. Steve | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | They have a flatter/thinner thichness head than a normal carriage bolt, but they do not have the flat head of an elevator bolt.
| | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | What kind of bolts are these, Dads50? Steve | | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | Tim, are referring to Dads50 photo? Steve | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | ...click... American classic truck parts | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | I pulled my running boards off today. A previous owner used elevator bolts to hold them to the brackets. One side of the head was partially filed off to allow it to fit into the slot on the running board. They worked fine. > 1/4" Elevator Bolts @ FastenalThe running board bolt kit that I bought from The Filling Station has the large head 1/4" carriage bolts discussed earlier. The bolts are referred to as "Step Bolts" in section 8.902 of the MPC. Part #128381, 1/4"-20X1". The Filling Station bolts have a bronze colored finish instead of zink. The kit has twelve bolts, nuts, lock washers, and flat washers (smaller outside diam that the ones posted by DADS50). Kit does not have the two standard 1/4" carriage bolts that go through the running board, nor does it have any of the other standard hex nuts and bolts required. 53Movinon - sorry for not responding sooner. The "cab seals mtl retainer" is the metal strip that secures the rubber seals to the cab. Note: The retainer is held in place by clutch head sheet metal screws. I did not buy the retainers; mine appear to be OK.
