4 members (J Lucas, Jman, Bill Hanlon, 54farmtruck), 325 guests, and 2 robots.
Topics128,168
Posts1,057,098
Members48,463
#875249 08/16/2012 5:09 PM
posted by bowtietim
Thanks to Mr. Chipmunk for his tech tip article.
This is the new reproduction truck handle beside a factory rear barn door handle. I had the barn door bezel re-chromed;it’s pictured behind the new reproduction handle.
handles side by side
I measured the length of the Original barn door shaft.
measuring the original barn door handle shaft.
The anti droop spring
anti droop spring
Removed the roll pin out of the shaft.
removing roll pin
The anti droop spring mechanism.
anti droop mechanism pic#2
The base bezel is now free to remove.
bezel ready to remove
Marked where I wanted to drill for the roll pin with a punch. The roll pin is in a different location than a front door handle roll pin.
marking pilot hole
drilling pilot hole
drilling 3/32" hole for rol pin
Marked a line where I needed to extend the square shaft.
marking where to grind
I taped the handle up so the chrome finish didn’t get damaged.
taping handle
An angle grinder with a 3m roloc grinding disc, used to extend the square stock.
angle grinder
Grinding the shaft square.
grinding shaft
Using a file to true up the edges.
flat file
I marked the shaft to be shortened.
shaft marked
shaft marked#2
The door handle shaft cut to length.
shaft cut to length
shaft cut
Slip the barn door mounting bezel onto the reproduction modified handle.
slip the barn door bezel on
Anti droop mechanism reinstalled on new handle.
reinstalled anti droop spring
anti droop spring
Barn door handle modification completed.
new barn door handle completed
handle completed
Thanks !!!
posted by bowtietim
1951 3100 Chevrolet
Tim,
Thank GMONIZ.
George sent me instructions on how to get your message to display.
I then played around and got rid of the quote box.
I hope the format of your message is OK.
Thanks to both of you guys,hopefully the problem gets figured out.
Thanks,Tim
1951 3100 Chevrolet
Wow! Nice Work!
Was it a one beer job?
1953 1 ton panel
Just for reference, this tip is in the Tech Tips area too.
1951 Chevy 1-Ton Panel
Pictures of the restoration on Photobucket
RIP good friend.
