8 members (moparguy, baldeagle, walter74, Sjm, Wooley, SmalltownTRKGuy, Sjm, Hotrod Lincoln, 1 invisible),
342
9
Mod | | | Forums66 Topics128,165 Posts1,057,089 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | I occasionally see a question posted about the glass bowl on a fuel filter or pump not filling completely. The good news is that they should not fill completely. I shot a video to show the fuel levels in my Durex Moraine GM #986640 fuel filter, and my '52-'55 glass bowl fuel pump that I cobbled together. < CLICK > Glass bowl videoAfter I turn off the motor, the glass bowl on the fuel filter usually fills completely. I assume that ... > Pressure remains in the line between the pump and the carb. > The pump does not allow the pressure to reverse through the pump. > So the bowl fills with the pressurized fuel in the line as air and fuel ooze past the float seat in the carb. Hope that the video answers the question about fuel level.
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | Awesome! Thanks Lonnie! I'm replacing my old glass fuel pump with a new one that has vac assist this weekend and I was wondering about the fuel level. | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | I love your glass filter unit! | | | | | Joined: Oct 2009 Posts: 127 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 127 | Great info and photos on filters. Anybody know where to find a filter element for the Durex Moraine cage bail type? Mine was missing. Is there any way the paper AC element can be made to fit? Any other ways to improvise?
52 3100 project 54 3100 / 3112 ice cream truck, next project
| | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | I don't know of an aftermarket filter element that will fit your Durex Moraine filter body. I see the filter elements on ebay occationally. Also, search http://collectorsautosupply.com/> Select an automobile brands > Choose "All years" for the year > Choose "Filters" for the section You may need to search a number of automobile brands. I have a .pdf pattern to cut a cork gasket for use between the body and the bowl. If you want it, send me a PM with your email address.
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Oct 2009 Posts: 127 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 127 | Since this Durex Moraine filter is nicely plumbed in to the original hard lines, could I run it without a filter element until I find an element? I am planning to put a modern in-line filter between gas tank and fuel pump, at least temporarily (just cleaned the tank). Thanks for the quick answer, will pm for the gasket pdf.
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Yes, you may leave a glass bowl filter-unit inline without a filter. | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | When searching for the Durex bronze filter element, you will also need the spring if you don't have one. It is bigger at the bottom than at the top. You may find a complete filter unit for about the same price as the element and spring. Nothing on ebay this morning. < CLICK >
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | In the 'upright' AC type pumps the glass bowl is the pulsator dome. The air pocket at the top is a vital part of the diaphragm and valve operation.. it provides an amplification effect (increases the vacuum) so improve performance. I have a free copy of the AC fuel pump rebuild manual at: http://www.tm9-801.com/tm9-1828a/index.phpRead the first chapter or two.. explains the workings in all its gory details. | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | pfarber, and others - Great info, thanks for the link. Gotta question - Where does the air come from that is in the fuel pump dome? I can understand that air can be trapped in the pump dome when it is installed. But I also see air bubbles entering the dome in my video in the first post in this thread. Same question for the fuel filter. My filter bowl fills to the top after the engine is stopped and sits for a few minutes. The air pocket returns when I drive it. Where does it come from? By the way - your videos on decal installation on your website are excellent. < DECALS AND VIDEOS >
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Just and observation, my 50 Buick filter runs at the same level as yours. The air is likely gasses and not pure air.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Lonnie - the "air" you see [absence of liquid, sometimes a vacuum], is the void caused by the pulsating action of the fuel pump and the intermittent opening of the carb needle - the pump has springs and valves that react to movement of the liquid and pressure change caused by fuel use, none of the flow is instantaneous or continuous - the input side of the pump is suction, the output side is pressure, the "lag" introduces the voids and the "air" comes from the tank, entrained with the fuel
Vern - I think the only time that "air" is really vapor is when the supply line is over heated, eg: vapor lock, maintaining a pressure that prevents the fuel pump from pumping
Bill | | | | | Joined: Feb 2004 Posts: 29,872 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,872 | Gotta question - Where does the air come from that is in the fuel pump dome? It's probably not "air"- - -it's vaporized fuel. A little vacuum on a very volatile liquid like gasoline is bound to make a little of it evaporate. That's what happens when a pump "vapor locks"- - - -there's not enough pressure provided by a weak pump to overcome the tendency of the fuel to boil in the pump and the line to the carburetor as the engine gets hot. Once a large volume of vapor accumulates, the pump stops moving liquid- - - -it's just pulsating vapor. The old practice of putting wooden clothespins on the fuel line and/or wrapping the lines with aluminum foil is simply adding an insulator to help keep the lines cool. Jerry
| | | | | Joined: Jan 2005 Posts: 75 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 75 | The glass bowls look like the ones on the Model As. If they are, a Fram 3039 filter will work well. It has a disc on top that gets pinched between the glass and metal housing. No spring is required. | | | | | Joined: Jan 2014 Posts: 3,690 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,690 | I'm still struggling to understand the flow of fuel through the filtet unit with an empty bowl. Thought I had it figured out a while back when I had it apart to replace the element. But this empty bowl thing has me puzzled.
1951 3100
| | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | It's probably not "air"- - -it's vaporized fuel. A little vacuum on a very volatile liquid like gasoline is bound to make a little of it evaporate. That's what happens when a pump "vapor locks"- - - -there's not enough pressure provided by a weak pump to overcome the tendency of the fuel to boil in the pump and the line to the carburetor as the engine gets hot. Once a large volume of vapor accumulates, the pump stops moving liquid- - - -it's just pulsating vapor. The old practice of putting wooden clothespins on the fuel line and/or wrapping the lines with aluminum foil is simply adding an insulator to help keep the lines cool. Jerry No, its air. The fuel pump is really a fuel vacuum AND a pump.. it sucks fuel from the tank.. so it would be very difficult for any substantial pressure to develop in the pulsator dome as any excess pressure would vent through the outlet.... also air is compressible (its actually that very principle that makes the pulsator work. | | | | | Joined: Feb 2004 Posts: 29,872 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,872 | Good grief Charley Brown- - - - -some people actually believe all that claptrap! Jerry
