| | | Forums66 Topics128,113 Posts1,056,614 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2003 Posts: 1,377 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,377 | I just picked up a 56 235 from a car that someone yanked the motor out by the rocker arm shaft and broke 2 rocker arms and bent one pushrod,what I need to know are the rocker arms and pushrods the same on hydraulic and solid lifters and are they the same from 55 to 62. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Both hydraulic and solid's use the same rockers. 1950-62* hydraulic and 1956-62 solid's use the same length push rods. *the parts book shows 1950-52 hydraulic as being a different length than 1953-62 but I cant see a difference.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Apr 2011 Posts: 181 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 181 | Try www.rockerarms.com in Anderson, CA. They always seem to have items like this available but make sure you give them the information so you can get the correct ratio. Normbc9 | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Chevs of the 40s has them for @$14.75
