0 members (), 140 guests, and 2 robots.
Topics128,105
Posts1,056,541
Members48,448
I just picked up a 56 235 from a car that someone yanked the motor out by the rocker arm shaft and broke 2 rocker arms and bent one pushrod,what I need to know are the rocker arms and pushrods the same on hydraulic and solid lifters and are they the same from 55 to 62.
Both hydraulic and solid's use the same rockers.
1950-62* hydraulic and 1956-62 solid's use the same length push rods. *the parts book shows 1950-52 hydraulic as being a different length than 1953-62 but I cant see a difference.
My Blog
1 Offline
Try www.rockerarms.com in Anderson, CA. They always seem to have items like this available but make sure you give them the information so you can get the correct ratio.
Normbc9
Chevs of the 40s has them for @$14.75
