3 members (baldeagle, Rusty Heaps, SWEET), 84 guests, and 4 robots.
Topics128,014
Posts1,055,327
Members48,419
#874993 08/15/2012 4:14 PM
What is the correct fuel pump for my '53 1 ton panel? It has a 55-57 235 in it right now and the current pump is a glass bowl. I like the glass bowl and would like to get another but the only one I see lists an application of 47-51. My current one went out on me today. I want to make sure it mounts to my engine correctly, works correctly and the fuel lines are routed the same.
1953 1 ton panel
Starting around 1952, the correct fuel pump will have the in/out ports angled 20-deg to the block ... not parallel to the block.
Chevs of the 40's has rebuilt glass bowl fuel pumps for your '53.
< CLICK > Chevs of the 40s
I "made" a glass bowl pump for my '54 by removing the top half of a '54 all metal fuel pump and replacing it with the top half of a reproduction pre-1952 glass bowl fuel pump. The two mated up perfectly. And the in/out ports were correctly positioned at 20-deg. Looks and works great.
- Lonnie
My '54 3104
LonnieC #875117 08/15/2012 11:36 PM
right on. Mine is actually the older style with the straight fittings, so I'll just order another one of them. Thanks for the help!
1953 1 ton panel
