4 members (Guitplayer, Hotrod Lincoln, Bill Hanlon, Gdads51), 125 guests, and 1 robot.
Topics128,109
Posts1,056,271
Members48,439
Need to know torque spec for 235 Main Caps Bolts front 3 are 9/16 rears are 1/2 Clevite bearing book shows all the same ? I an installing shims measuring housing bores then will install bearings dial bore and grind cranshaft to .002 clearance I have already done rods. Blueprinting A 235 for my 1937 chevy Thanks to Paul from this site for the engine Std.Std. for 100.00 no cracks any where. John The Honer
This says 100-110 ft-lbs.
Professional Novice
