1 members (Hotrod Lincoln), 61 guests, and 2 robots.
Topics128,049
Posts1,055,740
#874444 08/13/2012 1:56 PM
OK Bolters,I did the forum search and came up empty on if rebuild kits are available for 37-39 Lever shocks. Does anybody have Ideas? All the companies I found want to rebuild/core for $200-$400 pr. I just want the shaft seals? My application is on my Hot Rod P/U front and do not want tube shocks this time.Thx Sully
Sully
Here are good drawings of the SA and DA varieties.
http://chevy.oldcarmanualproject.com/1929_54chevyparts/07/424.HTM
The pages that follow list repair parts including bushings, sleeves and gaskets, etc, but I don't see any seals... Not saying it doesn't have them. I thought if one could find the original GM part number(s) there might be a way to cross reference them... ??
Somebody must be able to supply them to the commercial rebuilders.
Professional Novice
Thank You Sir. I'll check it out
Sully
