0 members (),
170
7
Mod | | | Forums66 Topics128,078 Posts1,056,035 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 5 New Guy | | New Guy Joined: Apr 2011 Posts: 5 | Need to know torque spec for 235 Main Caps Bolts front 3 are 9/16 rears are 1/2 Clevite bearing book shows all the same ? I an installing shims measuring housing bores then will install bearings dial bore and grind cranshaft to .002 clearance I have already done rods. Blueprinting A 235 for my 1937 chevy Thanks to Paul from this site for the engine Std.Std. for 100.00 no cracks any where. John The Honer | | | | | Joined: Nov 2000 Posts: 1,969 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,969 | This says 100-110 ft-lbs.
Professional Novice
