Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (55shaker, Otto Skorzeny, Hanks custodian, 48JimC), 119 guests, and 5 robots.
Topics128,281
Posts1,058,484
Members48,490
#87464 12/11/2004 3:52 AM
After rebulilding the 250 in my 69 c10, I finally went to start it for the first time. When I turned the key the motor was turning and then it looked like a big spark came from the coil. Now the engine will turn, but will not fire.
1) Is it a bad coil?
2) Could I have installed the dizzy wrong, causing the coil to throw a spark!
3) Did I wire something incorrectly?
I was really excited to get the beast running after a year of sitting in the garage, but I am now in bummerland and the wife is not happy. (she wants her parking space back.)
69 C10 LWB 250 L-6/3spd
79 C30 Crew Cab Dually 454 V-8/TH-400
"Takes more than a coat of paint to make it at Thunder Road!"
#87465 12/11/2004 6:36 AM
It sounds like something is shorting out the secondary side of your coil. That big spark tells you that something is wrong. Make sure the coil tower (where the coil wire plugs in) is clean and dry. If you know the coil is clean and dry and if the coil wire is good, it is time to gt another coil.
Remember 9-11-01--God Bless the USA
JUSTICE, not REVENGE, will prevail
1951 Chevy 1/2-ton Pickup truck
#87466 12/13/2004 4:32 AM
V
V Offline
Check the voltage to the coil , should be about 7 ~ 9 VDC & go to 12 VDC when you crank the engine .
Coil basic resistance test (wires off) is 1.5 ~ 1.9 OHMS between the two outer connectors .
Waxy stuff leaking out between the area where the plastic top meets the metal coil can is in fact wax (insulation) and means your coil is dead .
Lucky for you , Ontario Pick-A-Part is close by on Milliken Av. south of the I-10 freeway and you'll shortly find a nice brand new coil in there , if you need one , take along your Harbor Freight $2.99 multi-tester .
Please to note : if DPO has buggered upo the wiring in your truck and you find 12 VDC at the coil with the key on , you need an ignition coil that has 3.5 OHMS primary resisitance ! big differance here .
Never _ever_ leave the ignition key on whilst chasing electrical gremlins unless you put a scrap of plastic between the ignition points or you'll cook the coil .
If you're rich and decide to buy a new coil , get the better Epoxy filled one as it'll last longer .
I hope this helps...
-Nate
There is no problem so difficult it cannot be overcome by generous application of brute force & ignorance
