3 members (Bill Hanlon, ShopRag, 1 invisible), 67 guests, and 1 robot.
Topics128,049
Posts1,055,676
#874380 08/13/2012 10:15 AM
I was a bit dissapointed when the shop called to tell me 1 of the spindles was to worn to accept the bushing - slips right out.
I'm looking for a replacement now. is the 3/4 spindle the same as a 1 ton?
Mark
3B Offline
Hy Bigtonka, it is a little tricky to tell for sure with a Canadian parts book as our 3/4 and 1 ton trucks are just designated as 14 series. It looks like the knuckles are all the same for the 14 series from 1946 to 1951, hope that helps.
3B #874390 08/13/2012 11:10 AM
Ok - so the 1 ton is 1430, what was the 3/4?
It looks like I can get used ones from Bills Truck Shop, his catalog specifies 1/2 and 3/4.
Bah - Bill's doesn't have one regardless.
Machine shop is telling me that the hole spindle is out of round and an oversized bushing wont work...
If you can't find one, you could have it hard chrome plated to build it up, then ground back to size. They can mask it to limit plating to the bearing area.
Dave Evans
52_3100
Thanks Dave,
I think I have one sourced now, thanks to Fred Nixon.
3B Offline
Hy Bigtonka, 3/4 tons are the 1420 series, 1 tons are 1430 series, hope that helps.
Moderated by  Dusty53
