0 members (),
196
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#87456 03/05/2002 5:48 AM | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | While I have put my gas gauge problem on the shelf for a few hours, I'm overhauling my StopRay lights in back. When I converted from 6 to 12 volts, the upper (brake) bulb fits ok. But using the same size bulb for the lower (tail) is a dimensional issue. It's just too big. I cannot install the license plate glass in the driver's side fixture due to the size of this lower bulb. Also the red lens is smashed up against this same bulb so I cannot properly fasten the outside lens frame. What smaller size 12 v bulb with same base diameter and post dimension can I use?
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
#87457 03/05/2002 10:00 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Off the top of my rusty/corroded brain i can`t say. I would direct you to an auto parts store and hope they should have the knowledge to help.
#87458 03/07/2002 2:39 AM | Joined: May 2000 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: May 2000 Posts: 69 | Jim Carter sells an adaptor for the taillights. It's bent at an angle and offsets the lower light socket further back in the housing so you can use the larger bulb and still get the lens back on. E-mail if you need more info | | |
#87459 03/07/2002 10:58 PM | Joined: Dec 2000 Posts: 4 Member | | Member Joined: Dec 2000 Posts: 4 | I used the Taillamp Socket Bracket from Chevy Duty, part no. 49-491. The bracket is staggered, allowing the bigger bulbs to fit inside the lamp, even if you have the old thick glass lenses. | | |
