3 members (Leo, 5 Window 9434, dt235sd), 114 guests, and 10 robots.
Topics128,077
Posts1,056,017
Members48,433
While I have put my gas gauge problem on the shelf for a few hours, I'm overhauling my
StopRay lights in back. When I converted from 6 to 12 volts, the upper (brake) bulb fits ok.
But using the same size bulb for the lower (tail) is a dimensional issue. It's just too big. I cannot
install the license plate glass in the driver's side fixture due to the size of this lower bulb. Also
the red lens is smashed up against this same bulb so I cannot properly fasten the outside lens
frame. What smaller size 12 v bulb with same base diameter and post dimension can I use?
Craig
Off the top of my rusty/corroded brain i can`t say. I would direct you to an auto parts store and hope they should have the knowledge to help.
Jim Carter sells an adaptor for the taillights. It's bent at an angle and offsets the lower light socket further back in the housing so you can use the larger bulb and still get the lens back on. E-mail if you need more info
I used the Taillamp Socket Bracket from Chevy Duty, part no. 49-491. The bracket is staggered, allowing the bigger bulbs to fit inside the lamp, even if you have the old thick glass lenses.
