0 members (), 234 guests, and 9 robots.
Topics128,078
Posts1,056,052
Members48,433
#87454 01/20/2002 1:34 AM
I want to replace the dummy-light instrument cluster in my '62 c-10 with on that has actual gauges. If I am keeping the engine stock, am I better off finding an original gauge cluster or will an aftermarket set serve me better. I am thinking about using Stewart Warner "Wings" gauges if I don't use an original.
#87455 01/20/2002 1:44 AM
You should be able to use an aftermarket gauge without problems, I assume if the oil pressure and water temp are electrical gauges they would come with their own sending units. If they are mechanical then they should not present a big problem. The gas gauge would also have to match your present sending unit or come with its own sending unit to replace original. smile
