0 members (),
136
7
Mod | | | Forums66 Topics128,077 Posts1,056,032 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#87454 01/20/2002 1:34 AM | Joined: Dec 2001 Posts: 6 Member | | Member Joined: Dec 2001 Posts: 6 | I want to replace the dummy-light instrument cluster in my '62 c-10 with on that has actual gauges. If I am keeping the engine stock, am I better off finding an original gauge cluster or will an aftermarket set serve me better. I am thinking about using Stewart Warner "Wings" gauges if I don't use an original. | | |
#87455 01/20/2002 1:44 AM | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | You should be able to use an aftermarket gauge without problems, I assume if the oil pressure and water temp are electrical gauges they would come with their own sending units. If they are mechanical then they should not present a big problem. The gas gauge would also have to match your present sending unit or come with its own sending unit to replace original.  | | |
