| | | Forums66 Topics128,165 Posts1,056,987 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2012 Posts: 10 New Guy | | New Guy Joined: Jul 2012 Posts: 10 | Muddling through a lot of threads and i'm a bit confused. I have a 51 GMC 150. 6V positive gound. Just got the truck and i'm trying to sort out a lot of previous owner electrical messes. He put in a ballast resister and from what i think i'm reading in the threads, i don't need, nor want this for a 6V system. Is that correct? It's very very hard to start this beast and between the reverse polarity (he had it hooked up negative ground) , backwards wired coil, no connection to generator i can't believe i got it going at all. should i remove the ballast resister that he put in? | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | No need for a ballast resister on a 6V system. | | | | | Joined: Feb 2004 Posts: 29,866 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,866 | Yes! Remove the resistor, and get the charging system working! When the starter is running, you're probably down to 4.5-5 volts at the coil primary, even without a resistor. No wonder it's hard to start! Jerry
