| | | Forums66 Topics128,026 Posts1,055,409 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2009 Posts: 95 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2009 Posts: 95 | OK Bolters,I did the forum search and came up empty on if rebuild kits are available for 37-39 Lever shocks. Does anybody have Ideas? All the companies I found want to rebuild/core for $200-$400 pr. I just want the shaft seals? My application is on my Hot Rod P/U front and do not want tube shocks this time.Thx Sully
Sully
| | | | | Joined: Nov 2000 Posts: 1,966 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,966 | Here are good drawings of the SA and DA varieties. http://chevy.oldcarmanualproject.com/1929_54chevyparts/07/424.HTMThe pages that follow list repair parts including bushings, sleeves and gaskets, etc, but I don't see any seals... Not saying it doesn't have them. I thought if one could find the original GM part number(s) there might be a way to cross reference them... ?? Somebody must be able to supply them to the commercial rebuilders.
Professional Novice
| | | | | Joined: Feb 2009 Posts: 95 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2009 Posts: 95 | Thank You Sir. I'll check it out
Sully
