8 members (Gdads51, 55shaker, 32Fordpuchoptop, dwreills, chevy51truck, Phak1, klhansen, 1 invisible), 122 guests, and 3 robots.
Topics128,036
Posts1,055,458
Members48,422
#874432 08/13/2012 1:04 PM
Hey guys,
I have a rubber air hose that is about to fail at the hose end. I can see it getting puffy. When I repair it I'd like to use something other than a worm clamp. Is there something akin to a compression fitting available? I'm imagining something like what is used on the ends of braided fuel line.
Or does anyone have any other suggestions?
I don't like the worm clamps or crimp bands because they have a bunch of edges to get snagged on stuff. And that little tongue that sticks out past the screw really, really wants to slice my hand up.
regards,
Leon
Leon #874439 08/13/2012 1:30 PM
Go to You Tube.
Search Red Green Show.
Apply The Tool that lets women find you 'Handy' even if your not 'Handsome' as directed. eeeek
Give me ambiguity
or give me something else
CASO #874501 08/13/2012 5:45 PM
There is a barbed fitting out there that you insert and are done. Sold by Bowman/Barnes or KAR or somebody like that. I'll try to get more info.
MNSmith #874572 08/13/2012 9:29 PM
Apologies, the stuff I was thinking about is for low pressure applications.
Looks like Plews - Edelman make a reuseable fitting for air hoses similar to the reuseable type for braided hydraulic hose.
http://www.amazon.com/Plews-Lubrimatic-22-133-Reusable-Fitting/dp/B00176FBJG
http://www.doitbest.com/Air+Hoses+and+Fittings-Plews+Lubrimatic-model-22-133-doitbest-sku-578886.dib
And they still make ferrule repair kits
http://www.plews-edelmann.com/accessories/
MNSmith #874641 08/14/2012 9:29 AM
That's what I was going to say, you can repair/replace just as it was.
http://www.toolsource.com/hose-ferrule-crimping-tool-p-66151.html
or
https://www.partsmaster.us/SitePages/products.aspx?Code=11070101
It's no trouble to cut the old crimped sleeve off the hose, reuse the barbed fitting, and with a new ferrule and a tool to crimp it you're back in business.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
Grigg #875176 08/16/2012 10:13 AM
I usually replace the whole hose when the ends start getting really bad. usually the rest of the hose has cuts, gouges, burn marks from welding, etc.
Any FLAPS that builds hydraulic hoses should be able to replace the end on your hose for about $5.00. Most are 1/4" NPT.
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
Moderated by  MNSmith
