0 members (),
172
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,274 Posts1,058,433 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2004 Posts: 288 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 288 | At our local salvage yard there is a 55.2 or 56 Chevy pick up. I have a 55.1 with a 3:90 rear gear ratio and want to switch rear ends. I have been looking for a blazer 4x4 rear end but noticed this truck sitting up off the ground.
What type of rear end gear ratio would it have and would that be a better swap than the blazer.
I currently am running a 283SB with a 4 speed saginaw transmission and with the stock rear end pulling 2800 rpm at 55mph.
Chris 1955FirstSeries
| | | | | Joined: Oct 2001 Posts: 194 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2001 Posts: 194 | If it is a half-ton, it is probably a 3:90 also. | | |
