3 members (1955 1 Series, 78buckshot, Guitplayer), 89 guests, and 2 robots.
Topics128,127
Posts1,056,680
Members48,452
I ordered a rebuild kit from chevy of 40s for my 1 bbl rochester b. Bought a used rochester bc off evilbay.
Followed the rochester rebuild video on utube with mike from mikes carb shop and support photos from a link on bangshift.
Got a better power piston of my parts carb etc.
Followed the video to the letter .
shes leaking fuel real good out the pivot point of the lower butterfly. I tried swappibg the throttle body off my parts carb but less improvement.
1938 Chevy 1/2 ton Pickup
1940 Chevy 3/4 KD Pickup
1946 Chevy 3/4 ton pickup
1940 Chevy 1/2 KC Pickup
1939 Chevy 1.5 Truck
Ideas on what to check....should I punt? She ran when I parked her and sat for 2 years. I dont believe she was blowin gas out then.
She ran when I parked her didnt include brakes. They guy I got her from said just turn off the engine and shell roll to a stop.
I freed up the passenger front varnished wheel cylinder and replaced it with new parts. The driver side was stuck solid ...unbolted wheel cylinder to release pads from drum. No luck.
I called mikescarb shop and he said he is only doing 4 bbl stuff now 7 days a week. I did tell him thank u for posting that rebuild video as I had watched it before speaking to him.
Im running a factory 235 splask with my.leakchester 1bbl. I have a carter (w-1 I believe) somewhere in my shop.that.needs serious attention. Punt?
If the throttle shaft is loose in the housing, you will need to have bushings put in to fix the problem. Is it producing black smoke?
1951 1 Ton Completed
I have said this before and and have personally proven that this works. To fix a Rochester B, replace it with a Carter YF. It won't leak after that.
1946 1-ton Panel
1952 1-ton Comml. W/Grain Body
ODSS Lawman
ODSS Lawman
I agree with MikeE's post, I did the exact thing on my dual setup.
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
I am still running a Rochester and it is giving me excellent service. I will say though that the first one I rebuilt and used always presented a problem. Sometimes you have to try another one. The ones after the upgrade in 52 are much better.
Riding in the Passing Lane
If it leaks out the throttle shaft you are leaking past the needle & seat. It may have a piece of dirt in it or a float with gas in it.
Those are good carbs & simple to work on.
1972 Chevy c10 Cheyenne Super
I got a nice carter yf from a guy that just had it rebuilt by hobbs carb service pelham nh. Haha the manifold is 3 inches bolt patteen the carter is 2a 15/16 advance auto parts didnt have an adapter or riser recommended JCWhitney who does have anything or atleast sergio doesnt understand my rewuest
Suggestions?
Thanks for the input before and niw
Carburetion specialist
The Carburetor Shop
